NI TestStand
calling sequence on remote system
is it possible to call a sequence on the remote system using Test stand?
Message 1 of 10
(5,410 Views)
Hi Alagar,
In short: Yes !
First i would recommend to read Manual at chapter 5 under "Sequence Adpater"
Espeacilly take a look at sub folder "Setting up Teststand as a server for Remote Executions"
to configure your maschine in right way.
If this is done remoting should be very easy!
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 10
(5,405 Views)
hi J_dodek...
I have configured both teststand and System as per the manual... then also i get some errors...
I have attached the BMP file.Please see to it...
Message 3 of 10
(5,395 Views)
Hi Alagar,
What about the firewall on your maschine ?
Are you able to ping Ibrahim1 with your maschine ?
Greetings
juergen
--Signature--
Message 4 of 10
(5,384 Views)
hi j_dodek,
I have add exception in the firewall settings for the REngine.exe...
I can also able to ping to Ibrahim system ....
Message 5 of 10
(5,377 Views)
Hi J_dodek,
Is there any way to call the remote sequence....
Message 6 of 10
(5,357 Views)
I tried to write a  example. But i was able to install Remote Engine on my buisness maschine -> no Admin rights Smiley Mad
I will try on my private maschine this evening -> So just wait a few hours.
To call the sequnce from the remote maschine would create a directory and call it from there.
In my company all TS files we are using are on a servers directory so it must work.
I hope that is what you are descriping as "call".  This is not comparable with running a sequence on a computer
Greetings
Juergen
--Signature--
Message 7 of 10
(5,354 Views)
I have tried to install the remote engine as descripted in chapter 5.
I was logged on a admin on a local maschine -> But no access !!
no admin rights!
Well done i am using TS4.0  But last year i got it running under TS3.5
Question to other members here: What did i wrong ?
Greetings
Juergen
--Signature--
Message 8 of 10
(5,308 Views)
Hey i'm using TS3.5
 i also get the same problem...
Message 9 of 10
(5,282 Views)
Hi lordsathish,
Have you seen this article on error code -17851?
TestStand Remote Execution Fails When Using Windows XP Service Pack 2 With Error -17850 or -17851
http://digital.ni.com/public.nsf/allkb/157B530CE191D9348625700E003E9EA8?OpenDocument
Let me know if you are still having issues with remote execution.
John B.
Applications Engineering
John Bongaarts
Message 10 of 10
(5,127 Views)
