NI TestStand
Skip socket in parallel mode
Hello
I have a testchamber were  4 product are tested for 8 hours. I want to use Teststand 2014  (and C#) in parallel mode. I want to skip sockets that are failing during these 8 hours. Lets assume that after 2.5 hours socket 3 fails, then i want to skip that particular socket and continue with the rest of the socket. How can i do that
p.s.
I saw some post about this topic but couldn't find a good answer
(2,494 Views)
Hello Tonnie,
First of all, I think the Batch Model would better fit your needs. You will not open the test chamber during the whole test, so your 4 UUT are linked in a "batch". Parallel model addresses independant test sockets. I mean, a test socket could test 4 UUTs while another could only test one, and a third one none (for instance).
Then, using the batch model, the test system will wait all test sockets are finished to start another batch. I guess you write your test sequence to go to Cleanup if a test fail. If it occurs on test a socket, it will wait the end of others test sockets. So there is nothing particular do to to handle it.
Hope this helps,
(2,464 Views)
Accepted by Tonnie
Hello Mathiue
Thanks for your quick answer.
I will try your suggestion
(2,452 Views)
