NI TestStand
Slow expression edit
Hi All.
I have a problem with the ExpressionEdit, when I use it in labview, then it is slow to "open", I have managed to break it down to that it is when I write SequenceContext.AsPropertyObject to ExpressionEdit.Context... on my labtop this takes about 1sec, but on the testers (1-2Ghz) it takes 4-5 seconds....
What can I do about this ????.... or is there anything to do...
/Thomas
(3,561 Views)
Have a look at this example maybe it will help.
http://forums.ni.com/ni/board/message?board.id=330&message.id=10626&query.id=200414#M10626
Regards
Ray Farmer
Regards
Ray Farmer
(3,560 Views)
Hi Ray.
I have seen that example.... and it gives me the exact same result as in my code... ..
It seems to me that it takes this amount of time to "copy" the result form sequence.context into the expressionedit...
Try to measure the time it takes to fill the context... I see around 0.9sec.
/Thomas
(3,554 Views)
