NI TestStand
No Test Data to Log
During the weekend I got 2 erros on my test stations:
Error: -9012 Source: Process Model Active Sequence: MySequence.seq
Elaboration: (Process Model Error) No Test Data to Log Warning: There is no Test Data to log to the DB. This test will not be recorded in the database. Process Model Error: -9012
Any clue??
Both tests were running during the transition from Sat to Sun, could daylight saving time change have affected my tests?
(2,991 Views)
I assume you have never experienced this error before? Are you experiencing it any longer?
From your error message, it appears that while your program caught the error when attempting to write to the database, the error actually occured somewhere in your test steps. What would have caused your tests to "stop" generating data? What made you ask about daylight savings time - did your tests begin generating data again after the "jump back" hour (for instance, did your tests not work for the second 1-2 am hour but begin working again afterwards)?
Since I'm not sure what kind of data your application is logging, I'm not sure what could have caused this error. If you are taking timestamped data then perhaps your tests did not like data being generated with the same timestamp and threw an error. What kind of tests are you running and what language are they written in?
If you could give me more information, I'd be glad to help you out.
Matt M.
NI
(2,969 Views)
