NI TestStand
"Expected String Value" and Variable
I'm using TestStand 3.0 and have a Win2K box.  Is it possible to enter a variable (ThisContext.Locals.CompHex) in the box next to Expected String Value in the Edit String Value Test box?   I want to compare what I have in the above variable with Step.Result.String.  Earlier in the sequence file I capture the variable ThisContext.Locals.CompHex and save it as a string.  Then later after reading memory I want to compare what's in memory "Step.Result.String" with ThisContext.Locals.CompHex.  Hope this is clear enough.
Tony
(3,641 Views)
Howdy Tony,
Currently as of TestStand 3.5, you can't enter an expression in for the Expected String Value option. This has been sent in as a product suggestion to our R&D team.
However, one workaround is to use a Pre-Expression to set that string value property. So, in your Pre-Expression for that string test step, you could say Step.Limits.String = ThisContext.Locals.CompHex.
Hope this helps!
Best Regards,
Jonathan N.
(3,627 Views)
