NI TestStand
Specify StyleSheet In SequentialModel
The other option is to create a TestStand Public in your project folder.  Just setup the hierarchy like the TestStand folder.  Then repoint using the link above.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 14
(2,885 Views)
Specifying a custom public directory sounds more acceptable to me. This means that we would be able to contain this directory within a project hierarchy. Would there be a way of specifying the path to this public directory dynamically rather than having to edit the Windows registry?
Message 12 of 14
(2,884 Views)
Accepted by chris86
You can dynamically add search directories.
Or...
You can use the windows API to edit the registry.  The problem is you stil need to reload TS once you have made the registry change.  If you are using LV there are some VIs out there that allow you to edit the registry.
jigg
CTA, CLA
testeract.com
Message 13 of 14
(2,881 Views)
Awesome, thank you. I have learned a lot from you today. Smiley Happy
Message 14 of 14
(2,878 Views)
