Spreadsheet String to array
Hello everyone.  I need advice from all you TestStand champions out there
I want to convert spreadsheet string to array dynamically.
My entry point are strings i receive from LabVIEW (0.060000    0.000000    0.000000    0.000000    0.000000    0.000000 ... ....)
I want to fill in my 1D array teststand in number (DBL) or labVIEW Dynamics data...
I can add in a previous step a statement step.
Any idea how to do this ? insert elements function ?
BR,
Vincent
(5,403 Views)
Since it looks like you are getting this data from a VI, I say make that VI do the work for you.  There is a very simple Spreadsheet String To Array function in LabVIEW.
(5,394 Views)
Hello crossrulz,
Thanks for your reply
Indeed i get my string from this labVIEW function but I am using a VI to fill in all my TestStand parameters...
Here is an example of what kind of command i send :
AgilentB2901A ; SET_ARBRITARY_WAVEFORM ; PATTERN_MODE ; PATTERN ; DEVICEACTION ; DT ; NB_PATTERN_LOOP ...
I won't explain all command detail but for instance :
PatternMode means Voltage or Current
Dt means width signal sourced... etc...
Pattern represents the array of data i have already converted to string (0.060000    0.000000    0.000000    0.000000    0.000000    0.000000)
Now i want to find a teststand function which can have the same behaviour as the LabVIEW's spreadsheet string to array... to fill in my TestStand parameters...
Hope this bring light on my issue...
BR,
Vincent
(5,387 Views)
In other words,
With that string : (0.060000    0.000000    0.000000    0.000000    0.000000    0.000000)
I have to fill in an array of number teststand. (called "pattern")
I already set  "pattern" dimmension.
In another statement step i tried function "InsertElements" but the equality is false...
Locals.Pattern= InsertElements(Locals.Pattern,"[0]",Val(Parameters.SplittedCommandArray[8]))
Any lead will be appreciated !
NB : Parameters.SplittedCommandArray[8]) = (0.060000    0.000000    0.000000    0.000000    0.000000    0.000000)
I think my topic title is wrong ; should be : "Teststand create array from string" Any admin could modify this ?!
BR,
Vincent
(5,365 Views)
