Station Globals access (what's wrong?)
Ok, so two different applications each have their own instances of StationGlobals which were common until the launch of the first application. I can accept that (reluctantly). But how about multiple threads of the same application, are StationGlobals truly shared 100% of the time? My OperatorInterface depends on it.
Hurst C.
Message 11 of 12
(1,055 Views)
You should have no problems with using StationGlobals across threads as you would be using the same engine instance.
Regards
Ray Farmer
Regards
Ray Farmer
Message 12 of 12
(1,047 Views)
