Station Info using Batch Process Model
I have a test sequence that use a sequential process model and I grab station information using the following.
RunState.Root.Locals.StationInfo.StationID
RunState.Root.Locals.StationInfo.LoginName
I am creating a new test sequence which uses the batch process model - when I try to grab the Station Info data using the syntax above I get the following error
Unknown variable or property name 'RunState.Root.Locals.StationInfo'.
Can some please advise if I am accessing the wrong area when using a batch process model?
Thanks & Regards,
Shane.
(4,009 Views)
Accepted by ShaneDonn
In the batch and parallel models you can access this information using:
RunState.Root.Parameters.ModelData.StationInfo
-Doug
(3,994 Views)
