StationGlobals non volatil changes, API
I'm trying to modify the value of some StationGlobals values through the API, but the changes are made only during execution and i'm not able to store permanent changes...
I'm using this lines to made the change
PropertyObject myGlobals = runtime.AppMgr.GetEngine().Globals;
myGlobals.SetValString(sLookup, 0, tbVariableValue.Text);
Is there a method to save the changes permanently?
(706 Views)
IIRC, when using the API, you need to save StationGlobals.ini. Don‘t forget to increase the changecount before doing so.
(689 Views)
Accepted by GenerQ
Try this: https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/teststand-api-ref/propertyobjectfi... Engine.CommitGlobalsToDisk()
and this: https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/teststand-api-ref/engine_commitglo... PropertyObjectFile.IncChangeCount()
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(669 Views)
