NI TestStand
StationGlobals variables are disappeared when reboot PC after 3 days
I made some StationGlobals for configuration last week and booted today but can't see most of variables.
Is it possible to clear the stationglobal variables?
Not sure of this, I'd like to export stationglobals. Is it possible to export stationglobals?
When I doing more, problems are following more, unfortunately. 😞
Best Regards,
(3,846 Views)
Accepted by topic author gooohestpoo
Hello gooohestpoo,
StationGlobals are saved in a file, you can check if the file exists or is modified.
C:\ProgramData\National Instruments\TestStand 2016 (32-bit)\Cfg\StationGlobals.ini
For a check, if you want to make this file readable, you can go to
Configure -> StationOptions -> File -> File Format Options
and change the format.
Change the format after testing back to binary, because it is the fastes!
best regards
Alexander
(3,808 Views)
I had the same issue. I resolved this problem by using the same version of Teststand.
I have Teststand(32bits) and Teststand(64bits) installed on my pc . When I created the variables , i was working with Teststand(32bits). Then after restarting my pc i opened Teststand(64bits) so I couldn't find the variables.
When I opened with Teststand(32bits) , I found the created variables.
I hope this may help you.
(2,182 Views)
