NI TestStand
Stationglobals in a Labview custom step type inside a new thread do not get updated
I have a Custom Step type which I use to pass parameters to TestStand from a VI and vice-versa through some step fields. I run the VI inside a sequence in a new thread and expect the VI to update the parameters when I change them through the TestStand StationGlobals.
For example, I have a waveform injection custom step. I want to continuously inject a signal while I do some measurements on it. So, I put this step type in a sequence and ran it in a new thread.
I pass the VI parameter 'Stop_Injection' through a step field as shown in image 1. And I expect the step field to get updated when the new thread is run continuously by passing the corresponding stationglobal in the Pre-expression of the custom step (image 2). But this fails to happen. The VI does not get updated.
On the other hand, if I do not bother with the step field and directly pass the stationglobal (figure 3), it works perfectly.
Any idea why this is happening?
I hope I was clear in my question.
LabVIEW 8.6.1
TestStand 4.1.1
Message Edited by Changi on 08-06-2009 12:50 AM
(5,813 Views)
In image 3 you are linked directly to the StationGlobal of which you are continually updating therefore seeing the changes.
In the other you are only linked to the Step.Stop_Injection and are only updating this valve from the stationglobals once in the pre-expression. You are not changing the reference.
Regards
Ray Farmer
Regards
Ray Farmer
(5,804 Views)
Thanks Ray. What you say is correct. The pre-expression will be evaluated only once.
I was attempting it this way to keep my step type generic. If end-user decides against having the VI I used and develops some of his own or uses another adapter, then all he has to do is map the step fields to the appropriate variables in his code.
But I guess I cannot do this separation (between TestStand code and LabVIEW) if I want dynamic updating of the VI parameters.
(5,794 Views)
