NI TestStand
Step Count always zero?
Report generation sequence file, like reportgen_txt.seq shipped with TestStand, has step called "add step count". In my understanding it comes from model, like sequential model.seq, but I have always seen it to be zero.
I was interpretating this parameter in report would tell how many steps a test took in total, because my test execution may take different number of steps. Is my assumption correct that this parameter would tell total number of steps executed, including all step executed e.g. in a while loop ?
br
petri
(5,050 Views)
Accepted by Petri
Hi Petri,
Your understanding is right. "Add Step Count" step in AddReportHeader sequence adds the total number of steps executed in the test execution.
This parameter in the report will be 0 if you have disabled "Include Step Results" in Report Options dialog for the corresponding report plugin.
Hope this helps.
Sahana
(5,043 Views)
Thanks Sahana your reply.
That seems to be true in my machine when I have selected report generator option DLL. But when I have selected sequence option, which I want to use because I have a custom reporter to excel sheet, the step count remains zero. I'm not sure if something has happened with sequences, they are pretty old originally coming from TestStand 3.x. Anybody help to try this ?
Sequence file attached.
(5,028 Views)
Petri,
I executed the attached sequence in TestStand 2010 and  generated ASCII Text report using "Sequence" Option in Report Options dialog. In AddReportHeader sequence, total number of steps was not zero.
Consider sharing the configuration file C:/ProgramData/National Instruments/TestStand 2010/Cfg/TestStandModelReportOptions.ini so that I can further look into the issue.
Sahana
(4,999 Views)
