NI TestStand
Step result of new thread to be together.
In my Main sequence I have a thread running. How can I record the result of the steps within the thread together in the report.
Currently as the steps execute, result is recorded irrespective if the steps is in Main seq or in the thread.
Thanks!
(15,210 Views)
The thread is started using a sequence call. The result of this seqeunce call contains the reults of "the thread"
My understanding is, that the result generation also puts these results in the report, just as if you'd run a subsequence in the same thread
(15,150 Views)
