NI TestStand
Store in DB Step_Results variable value
Hi, I need to customize the Step_Results table of the TestStand Results.mdb. In the Step_Results table I added a new column. In this column I want to record a variable value when a test is executed. Basically, I need to know when a trest is executed what is the varialble value.
How can I do it?
Thanks a lot
(2,856 Views)
try to give a look to this tutorial
Creating a TestStand Database Schema from Scratch
http://www.ni.com/white-paper/6484/en
This tutorial explains the complete customization of an mdb report in TS
Regards
A
(2,846 Views)
