NI TestStand
TestStand 4.1 with Windows 7
When I launch TestStand with administrator rights, I have the following error :
Unable to access the TestStand configuration directory...
The solution is :
change the directory specified in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\TestStand\<version>\CfgLocation
The problem is that there is no TestStand Directory on HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\
Does TestStand 4.1 run with Windows 7 ?
(3,198 Views)
TestStand Lifecycle Support.
TestStand 4.2.1 is the first version running on Win7 as a supported version. Previous versions *might* run on Win7, but are not supported.
Norbert
Norbert
Expert: Geometry
(3,196 Views)
If you are using a 64 bit os and regedit.exe you need to look under the wow64 node for the 32 bit version of the registry.
(3,185 Views)
More specifically, you should be looking under:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\TestStand
if using regedit.exe on a 64-bit OS.
-Doug
(3,179 Views)
