NI TestStand
Str function not working
I am using an post-expression in an additional results step type step to add a comment in my report as below.
Step.Result.ReportText = Str("A", "Mode: % 50s", True). While executing if i see the resultlist variables the step output is 50 characters aligned. But when i see the report at the end of the execution the output is simply "Mode: A" with 50 characters alignment.
Pl let me know where i am doing mistake.
regards,
ramjee v
Message 1 of 8
(4,363 Views)
I dont have TestStand to hand, but dont you need a second boolean to say use formated  string.
eg str("A", "Model %50s", false, true)
regard
ray farmer
Regards
Ray Farmer
Message 2 of 8
(4,357 Views)
When i run as per the above comment, getting error say that "Error in argument 3, 'False', in call to the expression funcrtion 'Str'.
Pl let me know how shall i proceed.
Ramjee
Message 3 of 8
(4,350 Views)
sorry, parameter 3, <decimalPointOption>, is probably not a boolean I suggest you check the help to see what is a  valid entry.
regards
ray farmer
Regards
Ray Farmer
Message 4 of 8
(4,345 Views)
When I ran your statement using a TEXT report I got the following:
Mode:   < 50 spaces> A
You are generating a text report, right?  Is that what you were expecting?
PH
Message 5 of 8
(4,340 Views)
Accepted by topic author ramjeev
Going along with what Teds said - if you use HTML/XML/ATML reports, your browser will likely render the report text with only one space. To pad a field in a browser-compliant manner, use &nbsp; instead of a space.
Message 6 of 8
(4,331 Views)
hi Asbo,
I am using html report.
What is nbsb stands for in html report generation?
regards,
ramjee
Message 7 of 8
(4,313 Views)
"&nbsp;" is rendered as a non-breaking space.
Message 8 of 8
(4,290 Views)
