NI TestStand
String output with \t\n
I'm trying to add my string output to the report and the string output is something like this...."...\t\n, akfjdakjf\n, jaiejfiaje\n". When the string output is displayed in the report, it displays everything in one line (makes a long single line). I'd like the report to show like below..
ajkfj
ajfkd jkjfka
fjka
Really appreciate the help. Thanks~
(3,166 Views)
Accepted by 1234546111123
Could you please show us how you write the text into the report?
Please note that if this is a string variable you pass on, the '\n' is a static string and not evaluated in regard to escape characters. So if you want to have a new line there, the variable itself has to include the new line, not the '\n'-"command" for a new line.....
Hint: if you need a manual new line, you can insert one pressing Ctrl+Enter....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,150 Views)
