SubVIs are not running in Main VI, when it is run from TestStand
I'm calling a VI from test stand, which contains some subvi's, in the Main VI subvi's are executing when some button are pressed, however when I press any button in the front panel nothing happens
Regards
(3,434 Views)
Are the buttons triggering events?  How are the buttons calling the subvis?
jigg
CTA, CLA
testeract.com
(3,420 Views)
Can you post more information about how the subvis are getting call ?
(3,377 Views)
Accepted by VACV
Be more specific about what your main vi does?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,367 Views)
My Main  VI uses a event structure to handle the buttons action. Every button execute a SubVI.
However I fixed my issue using net world variables, with these I can access to Labview data from test stand.
Regards
(3,364 Views)
I'm using event structure to handle the buttons action, every time I press a button it launch an event and SubVI is executed
(3,363 Views)
This was the solution ?
(3,335 Views)
