NI TestStand
SubVIs are not running in Main VI, when it is run from TestStand
I'm calling a VI from test stand, which contains some subvi's, in the Main VI subvi's are executing when some button are pressed, however when I press any button in the front panel nothing happens
Regards
(3,538 Views)
Are the buttons triggering events?  How are the buttons calling the subvis?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,524 Views)
Can you post more information about how the subvis are getting call ?
(3,481 Views)
Accepted by topic author VACV
Be more specific about what your main vi does?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,471 Views)
My Main  VI uses a event structure to handle the buttons action. Every button execute a SubVI.
However I fixed my issue using net world variables, with these I can access to Labview data from test stand.
Regards
(3,468 Views)
I'm using event structure to handle the buttons action, every time I press a button it launch an event and SubVI is executed
(3,467 Views)
This was the solution ?
(3,439 Views)
