NI TestStand
Support for Older SW Versions
I would like to ask following thing about TestStand:
Does TS 3.0 save sequences in TS 1.0.1 format ?
If does how you do it and if not what you suggest for me ?
Br,
Tomi
Message Edited by tkoski on 04-07-2005 10:03 PM
(2,812 Views)
Hi Tomi,
You cannot directly save the TestStand 3.0 sequences to 1.0. TestStand can save formats upto two versions previous to the current version. So TestStand 3.0 will the sequence into either 2.0.1 or 2.0 version.
However if you have TestStand 2.0 on your machine, then you can open this TestStand 2.0 sequence and save it as TestStand 1.0 sequence.
I hope this helps
SijinK
(2,796 Views)
