NI TestStand
TestStand User Login
How do I change the login screen? It currently shows Administrator and no password. When I used the now obsolete Test Executive, one could login with any user name, and the password was either 'operator', 'developer', 'technician'.
(3,447 Views)
hi mrbean,
Under the administrator login, you will have to setup some users.
Have a look a the TestStand User Manual Chapter 7 - Adding Users and Setting Privileges (this is TestStand 3.0 it maybe the same chapter for TS3.1).
Hopefully this should answer all your questions
Regards
Ray Farmer
Regards
Ray Farmer
(3,445 Views)
