NI TestStand
Support the launch of an NI TestStand Idea Exchange!
muks is correct, you need to post this on the Feedback On NI Discussion Forum to Laura F.
Regards
Ray Farmer
Message 11 of 39
(4,391 Views)
Message 12 of 39
(4,386 Views)
Great Idea !
I support this.
Bruno
Message 13 of 39
(4,310 Views)
Good idea !
Message 14 of 39
(4,161 Views)
Good Idea
Idea i would like to see on the exchange:
If a property is going to be loaded by the property loader at run time I would like to see some notation by that property for debugging purposes.
Chill
Herrlin
Just trying to spread the LabVIEW love.
Message 15 of 39
(4,102 Views)
I'm in 🙂
Message 16 of 39
(3,930 Views)
If you have a type def in LW, and import this in TS.  There are and will be two independent incidents of the same type.
So if you change the type def in LW,  the TS type def don't follow.
And I have tried to manually update the type def in TS with the same change, but it don't work as expected.
I was forced to import it again and go through the hole TS and change every entry of the variables using this type def.
Message 17 of 39
(3,927 Views)
Please start a new thread!!!
Message 18 of 39
(3,930 Views)
Definitely have ideas and would appreciate the opportunity to put them up for review.  Our group is moving away from labview in favor of Visual Studio, but TestStand is such a great platform for sequencing steps that we decided to stick with it despite some of it's non-MS-Windows kludgySmiley Happyness.   TS 4 was such a great improvement over TS 3Let's keep up the momentumMake it so easy to use, nobody want's to work without itSmiley Happy
- Mark
Message 19 of 39
(3,752 Views)
If I were NI, I would be delighted to have a forum for getting the voice of the customer (to use a buzzword or buzz phrase). I think it's a great idea.
Message 20 of 39
(3,746 Views)
