NI TestStand
Switch from 32 bit to 64 bit and test stand no longer runs
I have a test stand and labview system that is largely using standard templates to run. I had to convert all my VIs from 32 bit to 64 bit to solve another issue and now my Standard User Interface no longer launches my process model. I've attached the part of the code where i think the issue may lie and can provide any info requested. Before the conversion, this code would start the process model, prompting a user for part number, etc, before loading sequence files.
any insight is greatly appreciated.
adam
Message 1 of 12
(2,864 Views)
Are you getting any errors when you run it?
Message 2 of 12
(2,846 Views)
no errors, it just goes into the "wait for user input" state without launching test stand.
Message 3 of 12
(2,814 Views)
adam
If you are configuring LabVIEW as Development Environment, irrespective of 32bit/64bit TestStand will execute without issues, But in Runtime environment both LabVIEW and TestStand should maintain same bit (if LabVIEW is 64 bit then TestStand also should be in 64bit , vice versa)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 4 of 12
(2,790 Views)
i am using 64 bit for both test stand and labview. Is there somewhere i need to specify which environment to use?
Message 5 of 12
(2,783 Views)
Check Config, Adapter settings.
Message 6 of 12
(2,780 Views)
that looks correct to me...
Message 7 of 12
(2,777 Views)
some further info, in case it helps. showing Register Event Callback and the configuration VI for everything.
Message 8 of 12
(2,762 Views)
Have you customized the User Interface? or using the default one as it is?
Message 9 of 12
(2,732 Views)
i believe it has been minorly altered by my predecessor, but it looks pretty close to the default to my eyes.
Message 10 of 12
(2,729 Views)
