NI TestStand
How to add UUTStatus (Passed, Failed) to Reports?
I am using TS 2022 and would like to add to the reports the UUTStatus with "passed" or "failed". To generate I use the callback "ReportOptions" for the BaseName, BatchBaseName etc.
This generates a reportname which looks like this:
Report DUT[07 48 54][06 04 2023].xml
How can I add to this report name the UUTStatus that the report looks like this:
Report DUT[07 48 54][06 04 2023] passed.xml
In the callback "ReportOptions" I can't find any parameter
Message 1 of 14
(2,088 Views)
Check for Configurations/ Report Options, where File Path can be Configured based on Expression.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 14
(2,056 Views)
Do you have an example where the batch report can be changed like you mentioned?
Message 3 of 14
(2,051 Views)
Specify Report File Path by Expression - NI
Message 4 of 14
(2,016 Views)
Well I know this document but the question is "which parameter in the callback ReportOptions -> Parameters -> ReportOptions" do I need to change and how the expression looks like?
Message 5 of 14
(1,991 Views)
Message 6 of 14
(1,980 Views)
Depending on which model you are using, the expression that you would need could be one of these:
Parameters.ReportOptions.ReportFileSequentialModelExpression
Parameters.ReportOptions.ReportFileParallelModelExpression
Parameters.ReportOptions.ReportFileBatchModelExpression
In my test it looks like this: "$(ClientFileDir)\\Data\\$(ClientFileName)_Report[$(FileTime)][$(FileDate)]$(Unique).$(FileExtension)"
Message 7 of 14
(1,975 Views)
So how would you combine the expression when the BaseName is set as:
Parameters.ReportOptions.BatchBaseName = "Report"
In case of the sequential model can you simply add it to:
Parameters.ReportOptions.ReportFileSequentialModelExpression = StationGlobals.ReportDirectory\\Parameters.ReportOptions.BatchBaseName_$UUTStatus.$(FileExtension)
When doing so, it does not work at all.. Any idea what is wrong with such expression?
Message 8 of 14
(1,944 Views)
I think you are misunderstanding TestStand variables.
Parameters.ReportOptions.ReportFileSequentialModelExpression is the name of a variable.  This variable is an expression string so it has be formatted as an expression:
If you are using Sequential Model:
Parameters.ReportOptions.ReportFileSequentialModelExpression = "\"" + StationGlobals.ReportDirectory + "\\\\" + Parameters.ReportOptions.BaseName + "_$(UUTStatus).$(FileExtension)" + "\""
If you are using Batch Model:
Parameters.ReportOptions.ReportFileBatchModelExpression = "\"" + StationGlobals.ReportDirectory + "\\\\" + Parameters.ReportOptions.BatchBaseName + "_$(UUTStatus).$(FileExtension)" + "\""
Message 9 of 14
(1,938 Views)
now I implemented as you wrote but the report name remains the same. This means only the $(FileExtension) is written while the $(UUTStatus) is still missing. When doing everything within the report GUI it works but unfortunately not when doing in the ReportOptions callback.
Message 10 of 14
(1,915 Views)
