Hey Dphan,
I think there is some confusion about the Deployment Utility. Part number 900851-01 is an old part number for the TESTSTAND DEBUG DEPLOYMENT ENVIRONMENT LICENSE. This is different form the TestStand deployment Utility which comes with the development environment. If you have the TestStand development environment intalled on a computer then you do not need either the debug or the deployment license. However if you are deploying a system to a computer that does not have TestStand installed you will need either the TestStand Debug Deployment Environment License OR the TestStand Base Deployment Engine License. This difference is that the Debug Deployment environment gives you more options for debugging. Please see the TestStand pages linked below for mor
e information.
TestStand Base Deployment EngineTestStand Debug Deployment EnvironmentIn summary you will create an installer using the deployment utility on your development computer (which has the development license). You will then install this on a target computer which will need either the debug or the deployment license.
I hope this helps!! Please let me know if you have any other questions.
Sarah Miracle
