Hey Dan,
TestStand ships with several example operator interfaces. There is a simple operator interface and a full-featured operator interface for several languages. You are correct the LabVIEW full-featured operator interface is in the directory TestStand 3.1/OperatorInterfaces/NI/Full-Featured/LabView. This is the same operator interface you use when you select Start >> All Programs >> National Instruments >> TestStand 3.1 >> Operator Interfaces >> LabVIEW. By default TestStand doesn't use any interface - it uses the interface you choose to open. You may be refering to the sequence editor. This is accessed by going to Start >> All Programs >> National Instruments >> TestStand 3.1 >> Sequenc
e Editor. This is not an operator interface and is provided for development. You can use it as an operator interface if you choose but we do not provide the source code so you will be unable to modify it.
If you're using LabVIEW then you can access the UI controls by going to the TestStand palette from the front panel of your VI. Go to the control palette and then All Controls >> TestStand. These are active X controls and can be used in any environment that supports activeX controls. I would suggest starting with one of the shipping operator interfaces.
In the future it's probably better to post separate questions to a new discussion forum thread.
I also noticed that many of the questions you've asked could have been answered by taking the week long TestStand course. It may be worth you while to spend a week and take the course.
TestStand Training CoursesI hope this helps!!
Sar
ah Miracle
