NI TestStand
TS_ExprCtrl_GetRequiredNamedTypeArrays is not setting the required named types to the edit expression control
can any one please solve my issue?
I am creating a step type in Labwindows.
I want to set required type of an expression control as array of type 'Protocol'
'Protocol' is a type which I have already specified in TestStand
I have initialised the variable 'ReqnamedTypes' as
char *ReqnamedTypes[1] = {"Protocol"};
I am using below two functions after loading and before poping up the panel in the same order
 TS_ExprCtrl_SetRequiredTypes (Lvi_pHandleEEP, PANEL_EEP2_BUFFER_ARRAY, TSUIConst_ValidExpressionType_NamedTypeArray));
 TS_ExprCtrl_GetRequiredNamedTypeArrays (Lvi_pHandleEEP, PANEL_EEP2_BUFFER_ARRAY, ReqnamedTypes, 1);
but in TestStand when I select a variable of type 'Protocol' it is giving an evaluation error as Expected <No type specified>, found Protocol
why it is not able to set the required named thpe for the expression control, am I doing any mistake?
I am using Labwindows 7.1, and TestStand 3.1
Thanks in advance.
Message 1 of 1
(3,354 Views)
