NI TestStand
How can I apply individual TestStandtests to elements of a cluster from Labview?
I want to bring a cluster from a LabVIEW VI into TestStand and then assign a specific test to each element of the cluster.  For example, the cluster might have numeric value that I would like to assign a numeric limit test to.  Or the cluster might have a string that I would like to assign a string test to.  Or the cluster might have a boolean that I would like to assign a pass fail test to.  How can I do this?
(2,820 Views)
The simplest way would be to simply use the appropriate test with the 'None' adapter to the TestStand variables that you have assigned to the cluster elements.
(2,818 Views)
