NI TestStand
TestStand annoyance with drop down boxes
I was wondering if anyone else is facing the annoyance of some drop down boxes only showing one line of information at a time. One has to click on the little scroll icons and see all other options one at a time.  I've attached a screenshot to try and explain what the issue is.
Amit
(3,819 Views)
No not seeing that problem.
What version are you using?
What are you running in and on what system?
Regards
Ray
Regards
Ray Farmer
(3,808 Views)
I'm using 4.0.1 on a Dell Laptop running Vista. Interestingly, I have no issue on a PXI chassis running XP SP2. I seem to be getting this problem mostly with dialog boxes. I've attached two more screenshots.
Amit
Message Edited by Amit Jayakaran on 02-24-2009 01:21 PM
(3,801 Views)
TestStand 4.0.1 does not support Windows Vista. You need to use TestStand version 4.1 or newer.
(3,754 Views)
I saw the same thing using the beta version of Windows 7 with TestStand 4.0.1, but I did not see the issue when I installed TestStand 4.1.1.
(3,747 Views)
