NI TestStand
TS_PropertyGetValNumber multiple numeric limit test
Hello
For a numeric limit test i get the testlimit in CVI with
tsErrChk(TS_PropertyGetValNumber(testData->seqContextCVI, &errorInfo,"Step.Limits.Low", 0, &MinVoltage));
How do i get the test limits in CVI for the multiple numeric limit test ?
Thanks in advance
(1,298 Views)
Sorry I don't know CVI but I did find this example white page that might be helpful.
Multiple Numeric Limit Test Step Type - LabWindows/CVI - TestStand 2019 Help - National Instruments ...
(1,286 Views)
Accepted by Tonnie
For multiple numeric limit step you need to get the values from the following variable :
So instead of step.limit.low use
step.Result.Measurement0.Limits.Low ( for the first limit and so on...)
Ravi
(1,266 Views)
