NI TestStand
TS2012 - No execution window at "run selected tests"
Hello OnlyOne
have you tried it on a different computer to see if there is the same behaviour?
I have checked it on a second pc, but the same result then on my.
best regards
Alexander
Message 11 of 17
(1,257 Views)
Hello OnlyOne,
please check your tracing settings under configure --> station options
they should look like this
best regards
Alexander
Message 12 of 17
(1,249 Views)
i checked the settings before running and after running. No changes - tracing is always activated.
I found out that it happens also when starting the sequence normally with the "play"-icon (not only with run selected tests).
I now disabled the model-sequence - but still not working. 😞
Message 13 of 17
(1,236 Views)
Hello OnlyOne,
i can´t reproduce this behaviour on WinXp, Win7 32Bit and Win7 64 Bit.
Have you tried to reproduce it on a second PC, if there is the same behaviour?
If you say that´s the same, if you run a sequence normally, then i think it could
be a corrupt installatoion. Please deinstall all, delete the folders and clean the registry
then start with a fresh installation.
best regards
Alexander
Message 14 of 17
(1,232 Views)
Some questions/ideas to help us reproduce the problem:
1) Can you attach a sequence that reproduces the problem without using "Run Steps" and without using a process model (i.e. the only thing you are doing is Run Specific Sequence from the sequence editor menu).
2) When this happens does the caption of the sequence editor show that an execution is running?
3) Is the execution in anyway perhaps marked as hidden?
4) Does this happen only in the sequence editor or can you also reproduce it in a UI?
5) If it happens only in the sequence editor, you might try doing "Reset UI Configuration..." from the View menu of the sequence editor and see if that helps.
-Doug
Message 15 of 17
(1,223 Views)
I was using the attached sequence from Duffy2007 on page on1
Yes, the title shows "running"
No
Not tested in UI.
Smiley Very Happy THIS WAS THE SOLUTION. AFTER DOING THIS IT WORKS! Smiley Very Happy
So today it seems to be solved. Will check in the next days/weeks if it stays like this.
Thank you verya much for this tip.
Message 16 of 17
(1,216 Views)
No problem. If that worked it means the layout file (i.e. settings for the UI layout) somehow got into a bad state. If you ever figure out how to make it happen again, let us know.
-Doug
Message 17 of 17
(1,212 Views)
