NI TestStand
TS2012 - No execution window at "run selected tests"
i am using TS2012 together with LV2012 on a Windows-7 64bit system.
Problem:
When i manually select one or more tests and rightclick to select "run selected tests" then normally there opens a new tab that show the execution an pass/fail of these steps.
But: Sometimes this new tab is not shown and  the tests are executed.
What can i do that is tab is always shown?
I looks for me like a timing-problem. When clicking to fast then its not working.
Is there a workaround?
(Currently no patches/updates are installed)
Thanks for help
Message 1 of 17
(4,352 Views)
Some questions since I am not able to reproduce this problem:
1) Are you doing this from a sequence file window or execution window (i.e. at a break point)?
2) When this happens is the execution document created and perhaps just not the active document (can you look for the tab for the new execution document)?
3) Can you reproduce this with simple empty expression steps, or only with certain steps in your sequence?
Thanks for any info,
-Doug
Message 2 of 17
(4,345 Views)
This happens in the normal sequence-file-window. Nothing with breakpoints.
There is 100% no new tab created. But the title of teststand say "running", because of this i found out that i clicked correct. At the first few executions i thought that i clicked wrong.
It just happens from time to time. I cant reproduce it manually. It happened with all teststeps no matter if i only select one step or more steps at the same time.
Message 3 of 17
(4,343 Views)
Some news about this behaviour:
It seems as it happens only once per Teststand-Start. This is how i can reproduce it here:
1. I start TS and open my sequence-file
2. I select some steps and "rightclick+RunSelectedSteps"
3. Now a new tab is opened and the test-results are displayed
4. Then i switch back to the sequence-file-tab (the result-tab is still visible)
5. The steps are still selected and i "rightclick+RunSelectedSteps" again
6. NOW the result-tab closes but the steps are executing (what is shown by the "running"-text in teststand-title
7. All next "rightclick+RunSelectedSteps" are normally and the closing of result-tab does not happen again.
Any ideas someone?
Message 4 of 17
(4,335 Views)
Hello OnlyOne,
i have tried to reproduce this with TS 2012 on Win 7 32 Bit system,
but it worked like expected, after starting the selected steps TS always
switch to the execution tab and shows the execution and the result.
One additional question are you testing in TS or in a custom user interface?
Attached the sequence.
best regards
Alexander
Message 5 of 17
(4,326 Views)
Can you do the same with labview-teststeps?
Thx
Message 6 of 17
(4,321 Views)
No need to test for you with labview.
I tried your attached sequence-file and have the same error with it: The second "RunSelectedSteps" does close the result tab 😞
Do you have any updates installed for TS?
Message 7 of 17
(4,313 Views)
[How can i edit my postings?]
I execute this directly in Teststand.
I checked for Updates but there are no available for me.
Someone here with a valid service-contract to chck this? Smiley Wink
Message 8 of 17
(4,310 Views)
Hello OnlyOne,
thats my TS version
and with the LV steps it also worked
What LV and TS Version is in use on your system?
best regards
Alexander
Message 9 of 17
(4,298 Views)
I have exact the same Teststand-version:
2012f1 (5.0.0.262)
Message 10 of 17
(4,294 Views)
