NI TestStand
Terminate at breakpoint but execute cleanup
At a TestStand step breakpoint I sometimes realize that the sequence is not going to work and I need to make a change.
Is there a way to go to cleanup from a breakpoint? I have an object that needs to be closed or my system is left in a bad state.
(1,825 Views)
Since you are manually interacting with the Sequence Editor anyway, the easiest way is probably just to close the execuiton window (see below)
(1,804 Views)
So closing the window this way runs cleanup?
(1,779 Views)
Accepted by stephenb2
Kind of...
More precisely:
Terminating an execution always runs cleanup sections. So if you are using exactly this way, your cleanup sections will be executed
Side note: you might be wondering, why you don't see the tracing while terminating and if you're setting a breakpoint in a cleanup section won't show any effect while terminating. This is due to the following default settings:
(1,758 Views)
Thanks for the suggestion. I can see that the cleanup steps get executed after termination with the station options for tracing set up this way.
(1,728 Views)
