NI TestStand
Termination does not appear as fail sequence
I have I a subsequence than include some Action type step.  The step set a local variable.  Based on that variable I decide whether to continue or to terminate.
In the event of termination, the process is indeed terminated, but when I look at the report generated by TestStand, the subsequence have a Pass mark.
Is this normal?  I would have expected to see Fail or Termination....  How do I fixe this problem to show a fail sequence?
Rafi
Message 1 of 10
(4,937 Views)
Hi Rafi
Your are right !! (I have tested it under TS4.0) After six years of Teststand programming i assumed that it should work as you descripe !
It seems I am wrong !?
I have wirtten a wrapper in the EngineCallback SequenceFilePostResultListEntry to filter TerminationState an add this feature to the report.
Greetings from the lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 10
(4,925 Views)
It returns a "Terminated" status in TestStand 2.0. So something has changed in the later versions.
Regards
Ray
Regards
Ray Farmer
Message 3 of 10
(4,922 Views)
This is fixed in TestStand 4.0.1. It now returns a "Terminated" status for the sequence call.
Message 4 of 10
(4,907 Views)
I ran Juergen example in TS 4 and it indeed showed Passed for the SequenceCall (by the way I delete the Callback).
When I ran my example it showed Terminated.
The Different being, in Juergen example he used ThisContext.Execution.Terminate() to force the terminate.
In my example I used the Post Action of the step to force the Terminate.
But as dug points out its been fixed in 4.01.
Regards
Ray
Regards
Ray Farmer
Message 5 of 10
(4,899 Views)
Hi, Ray
Thanks for your tests. I have also tried with PostAction now. But the result is still the same.
How have you done this Smiley Wink?
By the way as Dug said in TS 4.0.1 it is fixed.
What do you think about updating to the newest version ?
I am concernd when i received a letter from NI about latest DAQmx problem
(infocode rda4a4) and this affects TS 4.0.1 and CVI 8.5
Greetings
Juergen
--Signature--
Message 6 of 10
(4,889 Views)
Do you mean this
http://digital.ni.com/public.nsf/allkb/28637F55A85EAD64862573A900008D3B
If you are using DAQmx then I think the concern is getting a working DAQmx without corrupting the rest of your system.
I dont think there is a problem with upgrading to TestStand 4.0.1, it would depend where you are in your developement cycle.
I would check out the release notes before proceding.
And of course backup your work before upgrading so you have a stake in the ground to go back to.
Regards
Ray
Regards
Ray Farmer
Message 7 of 10
(4,883 Views)
j_dodek,
You can download TestStand 4.0.1 here.  This evaluation software does not include DAQmx, so you will not be affected by the troublesome behavior described in the letter you received.
Or if you received the TestStand 4.0.1 disks, if you don't install the included driver CDs you will not be affected.
Josh W.
Certified TestStand Architect
Formerly blue
Message 8 of 10
(4,873 Views)
Hi Juergen,
Nothing is setting RunState.SequenceFailed = True.
I added the line RunState.SequenceFailed = True both the Terminate() in the Post Expression of your Forced Terminate Step of your MySequence and it then made the SequnceCall step in MainSequence to be Failed.
Regards
Ray
Regards
Ray Farmer
Message 9 of 10
(4,853 Views)
Hi Ray
I added this line and it works great
Thanks a lot
Rafi
Message 10 of 10
(4,824 Views)
