NI TestStand
change numeric format
Is it possible to change and save the numeric format parameters of a custom steptype in Teststand 2.01 ?
(4,089 Views)
Yes it is. When you define your step type. Select the property you want to format. eg Result.Numeric. Right mouse click and select Properties. You will get the Numeric Properties Dialog. There will be a button called 'Numeric Format...'on the panel. Click on this and a new dialog will appear. This will allow you to format this property.
Repeat this for act for another property.
Now you custom step type will have formatted Result value.
I have attached an example of a custom None Adapter NumericLimitType which has the Limits and the Numeric result formatted to Unsigned Integer.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(4,089 Views)
How can I modify this using cvi code?
(3,888 Views)
Never mind, I figured it out. Thanks.
(3,886 Views)
