NI TestStand
Test Stand Deployment; Internal Error Code 1
Hi Rick,
I think you miss understood my response.
I was referring the the set of VI's that are shipped with TestStand in the Tools\Depolyment folders.
There is quite a bit of code that is shipped with TestStand that allows the user the ability to customise TestStand.
I was going to look at adding to the error message the actual VI that the deployment tool was having a problem with.
Regards
Ray
Regards
Ray Farmer
Message 11 of 14
(1,312 Views)
Hi Anand,
Here is copy of one the VIs that I think are causing the problem useing .Net. As I said before I have no problem runing these VIs using TestStand 4.0.1 runtime /development engine however I can not use TestStand 4.0.1 deployment tool to deploy my application when this VI or any others with .Net is selected. Any help would be appreciated.
Regards
Mehran
Message 12 of 14
(1,301 Views)
Just incase you have problem opening last VI attached is bitmap file of the same VI.
Mehran
Message 13 of 14
(1,299 Views)
Mehran,
I was able to open the test file- but I was missing the assembly that it used so I could not test it directly.  I made up two similar test VIs- one that invoked a method from an assembly from the GAC and one that invoked a method from a private assembly.  I was able to deploy both VIs using TestStand 4.0.1 and LabVIEW 8.5.1.   If you want to attch the assembly I can try deploying you test VI.   Is your assembly in the GAC?  If not what is the relative path between the VI and the assembly?
-Rick Francis
Message 14 of 14
(1,274 Views)
