NI TestStand
Test UUts with iEngine newExecutionMode
Hi Folks, I usually do not work with Teststand, therefore this question might be totally dumb:
I am trying to start an execution with the newExecution method of the Teststand engine. There is a string parameter "SequenceNameParamater".
I would like the standard (out of the box, fresh install) sequential model to ask for the UUT, means to do "Test UUTs". I don't know which parameter to use. "Main Sequence" starts the Main Sequence, but what is the value for the first entry point, that loops over the UUTs?
Thanks in advance
(2,772 Views)
If you want to execute the main sequence of a sequence file with the Test UUT entry point, execute the NewExecution function with the parameters :
- an SequenceFile object which contains the MainSequence you want to execute
- 'Test UUTs' string
- an SequenceFile object which contains the entry point you want to use
You will have more details int the TestSTand example 'Executing Sequences Using API'
I also suggest you have a look at the user interfaces code provided by NI with TestStand
Hope it helps
Regards
(2,728 Views)
