NI TestStand
report "no parameter or not recognized by teststand while changing function of Extraputty
Teststand reports "This function does not have parameter information in the DLL or uses tpye not recognized by Teststand"  when the function of ExtraPutty is changed  in the  ExtraPutty example "TestStand sequence.seq". I don't know why.
(2,710 Views)
It's just an information message saying that the dll has no information about parameters of the selected function. It means that you have to enter manually all the parameters of the function with the right type.
It seems that it is what you did. Do you have problem at execution ?
Regards
(2,668 Views)
