NI TestStand
TestStand 14 Sequence Editor's new features
Since TS14 there is a pretty nice feature when opening sequnce files from older versions.
Typically there was always a star behind your file. Now it is a +. Pretty good because now you will see that "automatic" update
has been performed.
Is there a documentation about such new features, because i was not able to find it in the feature list.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,197 Views)
http://www.ni.com/white-paper/52330/en/
You mean like that?
http://zone.ni.com/reference/en-XX/help/370052N-01/tshelp/infotopics/2014whatsnew/#AddEnhancements
or that?
The problem is that sometimes it takes a while to upgrade to the latest version of TestStand and so maybe 2 or 3 new ones have come out since then.  You not only need to look at the features in the latest version but any that have appeared since you last upgraded.
http://zone.ni.com/reference/en-XX/help/370052M-01/TOC2.htm
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,184 Views)
Hi Jigg,
Thats not what l am looking for.....
BTW the white paper was new to me.
Especially the graphics of sharing variables .net/Labview.
NI is pointing it out in help-files, i have read it... but the graphics had more impact to me!
Another great feature as well.
Regards
Juergen
--Signature--
(5,180 Views)
Glad you like that feature. Most of the new features are listed here:
however that one seems to be missing from the list. You are correct that the '+' indicator is to show that a file is modified due to conversions that occurred when it was loaded. You will also get a '+' if the file was modified at load time due to type conflict resolution.
Let us know if you have any additional questions or feedback regarding this.
-Doug
(5,179 Views)
Hi Doug,
thanks for pointing out.
I was just wondering if there are more characters implemented.
Maybe you have a feature for "#"  Smiley Very Happy
Regards
Juergen
--Signature--
(5,176 Views)
That's unfortunate that this got overlooked in the documentation.  I figured out what it was but I did have a couple guys on my team who misunderstood it.  Thanks for clarifying the data type as well.  I only assumed it was for files saved in different versions of TS.
Good stuff.
jigg
CTA, CLA
testeract.com
(5,174 Views)
Good stuff.
There is a tooltip that's displayed that explains the meaning of '+' if you hover over the document tab for a document that's showing a '+' (perhaps this is too subtle though).
Basically, '+' means the file was only modified indirectly by things that happened at load time and not by any direct user interaction.
And no, there is no '#' or other symbols with different additional meanings, just '+' and '*' for now :).
-Doug
(5,170 Views)
