NI TestStand
TestStand 2013 issue on Windows 10 computer.
We have installed two Windows 10 machines and are trying to run sequences on TestStand 2013 as we do on Windows 7 systems. Unfortunately, when executing any sequence from the Sequence Editor, after analysing it and pre-loading the necessary modules, the Sequence Editor gets stuck forever (hourglass) and does not show the execution window, so we have to abort the execution. We believe that it has something to do with the Model Plugin sequence call within "ModelSupport.seq". The Station Options settings, Search Directories and Result Processing are the same as on the other Windows 7 machines. Are we missing something?
Thanks in advance,
Enrique
(3,170 Views)
TestStand 2013 is not compatible with Windows 10.
http://www.ni.com/teststand/product_lifecycle/
Regards
Ray Farmer
(3,154 Views)
Accepted by mboobaa
Hi Jay,
Thanks for your quick reply and the information. We finally managed to fix the issue. For some reason, the "System Exec" function did not return after launching OpenSSL in one of the VIs, so the rest of the VI did not execute. We had to set the "wait until completion?" input to FALSE. The funny thing is that it's set to TRUE for all the Windows 7 machines.
Enrique
(3,147 Views)
