TestStand 2016 : Step Setting : An error has occurred. Save your work and restart the sequence editor.
The utility that we are investigating creating would be released as a KB and I would like it to be released by the end of this year if possible.
Scott Richardson
https://testeract.com
Message 21 of 22
(832 Views)
The tool to upgrade previously existing custom numeric limit step types to add EQT support is now available on this KnowledgeBase article:
Custom Numeric Limit Test Step Type Shows an Error in Step Settings in TestStand 2016
Additionally if you are not using the EQT feature, this scenario should no longer produce an error as of the f2 patch for TestStand 2016.
Kevin Flanagan
Product Support Engineer | Automated Test Software
Message 22 of 22
(429 Views)
