NI TestStand
TestStand 2023 compatibility issue with 2017
when trying to open Teststand projects saved with version 2017 (Parallel model) I have the following error (Error Code -17329  Invalid type -conflicts with an existing type Source TSAPI)
Does anyone know how I can please solve it?
Thanks in advance,
(785 Views)
Accepted by juanfer23
This error is independent of TS2023.
It is "just" a type conflict... are you using any customizing?
Which setting are you using for automatic type conflict resolution?
(781 Views)
Thanks for you answer.I have already found the issue. It was LV2017 32 bits and in the other computer with 64 bits.
Sorry for the inconvenience and Thanks again!!
(749 Views)
If anyone has the same problem here is the answer:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PA2rSAG&l=es-ES
(714 Views)
