NI TestStand
TestStand 4.2 Continuous Testing issue - same Time reporting for every UUT
hi,
i have this issue on my TestStand 4.2, everytime I do continuous testing (Execute >> Test UUTs), each UUT has the same Time in reporting.
What I need is how to modify the process model in such a way each UUT should have different Time in reporting.
Please see image below for reference.
thanks,
val87
(4,301 Views)
Val,
the time resolution of Starttime is seconds. Your test for each UUT has 0 results and the firs took 200ms, the others took less than 20ms each.
You can potentially test more than 40 (!) UUTS before getting a new start time stamp.
Norbert
Norbert
Expert: Geometry
(4,290 Views)
Accepted by val87
Hi val87,
This is a known issue with TestStand 4.2. The KnowledgeBase article below explains how to correct this behavior.
Why Does the Time Field of the UUT Report Header Remain Constant for Multiple UUTs when Generating XML Reports in TestStand 4.2 and TestStand 4.2.1?
http://digital.ni.com/public.nsf/allkb/8EE51C3635751A808625774A0050C214?OpenDocument
Let me know if this works for you!
Jake H
Applications Engineer
(4,281 Views)
hi jake,
the provided link helps.
thanks,
val87
(4,272 Views)
