NI TestStand
TestStand API - Sequence Call
I need to write a sequence programmaticaly and in order to do that I have to add the step "Sequence Call", but I'm not able to do it.
Have you got any idea?
Fabio
Message 1 of 8
(5,323 Views)
Hi Fabio,
I pretty big subject, but as a starter for ten.
You could create a Call Sequence step, using the TestStand API called from LabVIEW, using something like this
The Sequence your Sequence Call step is calling would need to exist.  You could create a sequence using something like this.
Regards
Steve
Message 2 of 8
(5,319 Views)
Hi Steve,
thank you very much for your answer. I did what you suggest me, but unfortunatelly I'm not able to identify the right "Adapter Type". If I select "StepType_SequenceCall" (it is the value SequenceCall) I received the -17336 error. Have you got any idea?
Fabio
Message 3 of 8
(5,311 Views)
Accepted by fabio.int
Hi Fabio
Apologies, here you go.
Steve
Message 4 of 8
(5,294 Views)
Steve,
thank you very much for the support!!!
Message 5 of 8
(5,278 Views)
Sorry,
I'm not able to add the sequence at this step. What is the property?
Fabio
Message 6 of 8
(5,239 Views)
Hi fabio.int,
Once you have created your sequence and your step than you need to insert the step into the sequence using something like this.
Regards
Steve
Message 7 of 8
(5,237 Views)
Hi Steve,
my problem is how to add the sequence in the step. Please look at the picture. How I can put the filename with the API?
thank you very much!!!
Message 8 of 8
(5,219 Views)
