NI TestStand
TestStand API to execute sequence file as Single Pass
Hi all,
How to execute the sequence file in a Single Pass from teststand APi in C# ?
I have modified the example "Teststand UI with Native Conrols" to run a sequence file.
For now I'm calling the below function:
private void executeButton_Click(object sender, EventArgs e)
if (axSequenceFileViewMgr.SequenceFile != null)
axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 0).Execute(true);
else
MessageBox.Show("You must open a sequence file before you can execute.");
(2,089 Views)
Accepted by ngupta4
Hi Ngupta4,
in your statement axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 0).Execute(true); call, is that last integer parameter a index? if so then try changing it to 1.
I see that my user interface has a index =0 for Test UUTS, Single Pass has a index=1, i'm using LabVIEW so can't directly compare to your code.
regards
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
(2,072 Views)
