NI TestStand
TestStand, DIO and MAX
I can go to Measurement and Automation Explorer and select my NI USB-6501 Test Panel, select the correct port and line depress the Start button and my relay closes.  See attached example.  Is there a way in TestStand to close the same relay without relying on a custom step type?  Can you point me to where I could execute this operation in TestStand.  Thanks.
Tony
(3,401 Views)
Hey Tony,
You could use an IVI step to perform your switching.
http://www.ni.com/white-paper/10092/en/
Oli
(3,373 Views)
