NI TestStand
TestStand - Default Values 82.llb missing
I've recently upgraded to Labview 8.2 (I already had TestStand 3.5), and when I try to call a VI using some default parameters and some defined parameters, I get an error saying that "C:\Program Files\National Instruments\TestStand 3.5\AdapterSupport\LabVIEW\TestStand - Default Values 80.llb" is missing.  Where do I get this file from?  In the directory I see versions of this file for 8.0, 7.1 and 7.0 only.  I've tried reinstalling TestStand and LabVIEW, but the installation options say everything is already defined, and i don't see an install component for anything like TestStand 3.5 LabVIEW Support.
(2,981 Views)
Copy the 80 version, rename it 82.  Mass compile this LLB in 8.2.  This should fix your problem.
Allen P.
NI
(2,974 Views)
