I've recently upgraded to Labview 8.2 (I already had TestStand 3.5), and when I try to call a VI using some default parameters and some defined parameters, I get an error saying that "C:\Program Files\National Instruments\TestStand 3.5\AdapterSupport\LabVIEW\TestStand - Default Values 80.llb" is missing. Where do I get this file from? In the directory I see versions of this file for 8.0, 7.1 and 7.0 only. I've tried reinstalling TestStand and LabVIEW, but the installation options say everything is already defined, and i don't see an install component for anything like TestStand 3.5 LabVIEW Support.
