NI TestStand
TestStand Deploy to EXE
I am deploying a TestStand Solution into an executable format, but I reference a VI that is the graphical user interface by name. When I build the GUI into a executable the path to the vi is no longer relevant.  Does anybody know how to set the path to a VI that is now an executable?
This is TestStand version 4.1.1
K.
(3,973 Views)
Accepted by KevinR
Hey Kevin,
In this case you should probably use the Call Executable step.  Right Click>>Insert Step>>Call Executable or select it from the Insertion Palette.  It's there to call applications, which is essentially what you've built.  You can read more about it in the Help.
Hope that helps some,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,969 Views)
Jigg,
That's great, thanks!
K.
(3,948 Views)
